I don't exactly know what "Eurospares" is, if that's a manufacturer or a broker for cheap parts.
I've used a few Eurospare parts & have had no problem with them. I think a few cooling hoses, coolant parts like the pump and thermostat maybe, mostly for my 2003 since for the 2012s (RR & Jag XJ), I try to use as much genuine JLR as reasonably (to me, personally) within value.
After the first 5 years or so of using some Eurospare parts that haven't let me down (yet anyway), I trust them as much as a MotorRad, or any other aftermarket.
This is a pic of the pump I removed from my 2012 RR that apparently the indy shop (that worked on it for the previous owner) that swears they "only use genuine JLR parts" when I've looked into them for potential repars. Apparently they don't!
BUT it has not failed- I just removed it during the course of trying everything else to find my nagging cooling gremlin (BEFORE the ultimate hail-Mary that I'll get around to eventually of pulling the heads to look for warped heads/block). So I replaced most everything, and used Genuine JLR (out of personal preference, not need).
TMI WARNING: details - I've tried a few leak "repair" snake oils, Blue Devil, a couple of Bars Leak products, without any of them really taking care of it. So although I never had any indications of the cooling system being blocked-up (I thoroughly flushed each out after not getting results I wanted), although when I vacuumed-out the oil cooler it did seem it may have been a little congested, I just wanted to get all new parts in. There was no indication of the snake oils in the parts I removed anyway, and as always it runs just fine in all conditions.
This is the back of that pump, you can see the EuroSpares logo. I'm guessing it's made by the same supplier as many other "OEM" aftermarket (and maybe genuine JLR parts too), but customizes the logo markings for the Customer - EuroSpare in this case.
Or maybe the vendor puts their specific logo on after getting an unbranded pump from the manufacturer.
BUT this is the Eurospare logo...
So as of now, both of our 2012 5.0L AJ133s have new genuine JLR pumps, BUT if one fails - I've got a good Eurospare ready to install if needed.
