1 - 11 of 11 Posts
2010-2012 Range Rover Sport
Anybody here installed puddle light in the backseat of RRS? Or anybody modified the oem light on the side to a puddle light so it turns on when opening the door? Lighting in the back of RRS is just terrible!
Not too long back I saw an old thread resurrected that had detailed description of how this was done to turn on the rear seat light when a door was opened. You should be able to do a search and find the thread.
Already did but nothing came up. Ill try change the wording hopefully something will pop up. Thanks!
2015 Range Rover
This was over if there best things I did. A few pointers. In the form I followed they tapped the new line into the bulb casing. For this caused a problem as there harness snapped. I would recommend pulling the wire out a bit cutting it and then swapping it and splicing at that point. Also def get the resisters so all lights don't come in when hit the switch.
1 - 11 of 11 Posts
