Just thought i'd post this up since I personally had this problem and was finally able to fix it.
If your rear headrests are stuck in backwards, simply twist the small plastic square on the seat where the rail goes in (the one without the adjustment button) and pull up on the headrest and it will slowly make its way out. Once it becomes mostly free I had to wiggle and push the button a bit then it came out completely!
