I'm a new owner of a Range Rover Sport (2009) and I've noticed that my rear glass hatch squeaks all the time, even on smooth driving surfaces. Any ideas on how to correct this issue?/:(
Lift the glass hatch up and on each corner you will see rubber bump stops. These are threaded and I had to back mine out so there was more contact/resistance when closed. It takes a bit of fiddling because you don't want to turn them too far out as when you close the glass the seams should be even, if you can follow that. I can take pics if you need after turkey lunch later. Hope this helps.
