I need to remove the rear floor panel as the fuel line from the pump to the filter has corroded and is leaking. Is the panel riveted or spot welded?
i am away at the moment so that’s why I can’t check on the vehicle
thanks for any replies
Should be revited plus the seat belt anchors..... but you should have an access panel to the pump. 1992 right?
1995-2002 Range Rover Classic
he is replacing the steel lines which mate to the rubber lines beyond the access panel.
thanks for the replies
Yes its 1992, yeah the steel pipe has corroded so need floor panel out to gain access
thanks
I was hopeful that there was enough access to get the pipe out & in. At least pulling the floor isn't too much work & gives you a chance to clean and do rust prevention.
Discussion Starter · #6 ·
yeah will give it all good clean and waxy, thanks for the help!
