Hi Guy's, ive got a 2011 l322 and the brake ware indicator has come up on the dash.
Ive taken the front pads out & they are ok, so I'm assuming that its the rear (they look a bit low, through the alloy spokes).
mine has got an electric handbrake, so I was wondering if there is anything that I need to know.
When I strip them down do the callipers wind in the same as any normal car? or do I need to do something different?
Many thanks in advance.
ASH
Rear brake pistons do not wind in, you just push them straight in (like the front brakes), they are separate from handbrake. If you change the rotors you should also inspect the handbrake pads and do a service if necessary.
