Yes seriously... if you read the workshop manual it describes the leak test which is basically the EVAP pressurization test with more diagnostic information. But you have to have specific software to access that feature. What it gives you is the ability to run the pressurization test on demand and determine what part of the test cycle is failing, that at least gives you a clue of where to look and the ability to verify what you find without having to wait for the right conditions for the test to run.
From the manual....
• NOTE: A leak test can be performed using the Land Rover recommended diagnostic tool. This overrides the above
conditions and is useful for checking correct system and component operation.
also has this.....
Disconnect purge pipe from the purge valve, observe the condition of connection (the seating and condition of
the "O" ring) and then reconnect. Using the manufacturer approved diagnostic system, run Purge Valve Self Test
(to clean the purge valve) then run the Fuel Leak Check
also one of the suggestions is to isolate the purge valve by using a plug in the purge pipe but this only works if you can force the test because not good riding around with both the purge and vacuum lines plugged waiting for the test to run...
.. my only point is that the ability to run the test on demand would be a great benefit to resolving EVAP faults... and shorten the troubleshooting time considerably, by allowing a specific procedure identify and pinpoint the specific area of the leak.
..Function wish list for the IIDTool
Regards
