Hi,
Can somebody please tell me where the Engine Management codes are described in the RAVE manual please e.g. P0150. Ive looked and looked but can't find them.
Phil,
Once again thank you very much. Did you get my PM by the way?
I've looked at my RAVE again and I have "System Description & Operation manual (wmlm011e.pdf)" not wmlm021e.pdf and is probably why I can't find them. I've searched and searched on the code numbers but nothing is found within the .pdf
This is a standard code; i.e.; not LR specific.
viewtopic.php?f=8&t=29534
P0150 Ox Sensor Circuit Malfunction (Bank 2 Sensor 1); Front HO2 sensor RH bank stoichiometric ratio outside operating band
Discussion Starter · #7 ·
Thanks - found them on a later version of RAVE - the last one before it went on line.
Discussion Starter · #8 ·
Forgot to ad :oops: This is the 2002 on > NAS version.
But... it says -
"P0150 LH bank front HO2S signal Circuit malfunction" not RH
I've changed the front RH (under the UK drivers RH side) yesterday and the P0150 code came back today... looks like it is the LH one after all :think:
AmI being stoopid :doh: :doh:
