I've diagnosed an annoying rattle coming from above my head.... Only happens on really hot days. It is the chrome accent piece that surrounds both the sunroof and sunshade switches in the overhead console. Pressing my hand on it stops the noise. The noise is ... extremely annoying in my otherwise bank vault Rover!
As a fix I've applied some lovely masking tape between the two.
Anyone know how to take this console off / down? I tried prying but it would not budge and don't want to break whatever flimsy frame is holding it to the headlining!
Hi, You can use a soft tool to lever it down at the rear (away from the front window) . It has quite a thick rim, so you have to push up with the soft tool further than you would first think before applying lever action. It has clips at the sides, you can just see one starting to appear in the photo below.
You won't break it. It should come loose with enough force and you'll need a couple of plastic prying tools. I'll try and post a video later this weekend if I get to it.
