Hi Newby here I have just bought a range rover 3 MY 2003. I need to fit a tow bar and would like a standard fixed hitch. I have heard that a fixed hitch towbar will effect the reversing sensors has anyone had this problem?
Mick
As long as you use the correct Land Rover module to connect the electic socket to the car, you'll be fine. The towbar won't be high enough to interfere with the function of the parking sensors in everyday use. When towing, the module should switch the rear sensors off when you select reverse.
I used an aftermarket module from ebay which works fine and turns off the sensors.
Stewart.
