1 - 20 of 56 Posts
Discussion Starter · #1 · (Edited)
Hello together
I have a Rang Rover Sport Hybrid 3.0 Diesel Autobiographie 2015 l494.
3 weeks ago I stopped, the battery was low and I could not drive anymore. It was taken to a garage. A new battery was fitted (not the hybrid battery).
Then I went on holiday and the car stopped again after 200 km.
It was taken to a garage again and I was told it was the hybrid battery.
I searched the forum a lot, talked to specialists and they told me that it is NOT the hybrid battery.
There is NO battery charging. If the hybrid battery was defective, I could drive the diesel. But the main battery is not charged again. This sounds more like alternator problems. If the battery is charged, I can drive 200 km until the battery is empty, and then nothing works on the car.
I have this error message:
P0A1F-49 Battery control module - internal electronic error.
P0AF9-00 Hybrid/electric vehicle battery system unstable voltage - no subtype information.
P0B53-00 Intermittent/irregular hybrid battery voltage detection circuit E - No information on subtype
P0C47-31 Hybrid/electric vehicle battery pack - coolant pump - open circuit
P0C47-39 Hybrid/Electric Vehicle Battery Pack - Coolant Pump - Open Circuit
Land Rover UK said that such a hybrid battery costs 40000 Euro and that the supplier is bankrupt and you don't know if you will get the battery this year or next year at all.
I need your advice because I need the Range Rover back urgently.
Range Rover sport Hybrid diesel 2015
Hello together
Hi,
I have the same problem as you did now.
In Greece the cost for hybrid battery is 38.333 €.
What did you do finally ?
Thanks !
My RR Sport L494 failed in July 21. UK dealer has had for some 4 months, and cannot tell me when they can supply! The car requires a full hybrid battery, it will not run/function without an operating battery. Possibly just a failed cell ?? However I have found a source and compliant installer 🤞 should anyone be interested. Battery and fitting circa £7k. Opposed to Land Rover UK £19500k 😡
i would be very interested to know. Could you please forward details. In Greece there is a Hybrid repair center up north which do the repair of Hybrid batteries with cost 3.500€.
My Range Sport diesel Hybrid 2015 already there waiting to be repaired , hope the result will be correct. to be on safe side please send details of compliant battery dealer.
Thank you !!!
Thank you !!!
Hi, Will check that it OK to send my repairers details. 3500 Euro sounds OK, compared to where Iam at 😡
We both crying but ok, yours are New mine will be repaired ! I will know results of repair after a while, when i will receive it they will work but for so long ?
Please ask and if they agree please forward details. Thank you ! Hope both cars will have no problem for long time !! :)
Yes, feel very angry. I asked when I bought the car who is responsible for the battery? Was told that was Landrovers responsibility. After all why would anyone buy this car if there was a limited warranty. I should have read the terms, to trusting! The people who say they can supply a replacement battery, are based in Essex UK. Small outfit but seem knowledgeable. You would need to have your car taken there, which is not plausible. I will ask if they can arrange a battery, and we can go from there 🤔 Good luck
So what exactly is the LR warranty on the battery?
Can you share details of the company ?
could you send me details of the supplier / installer ? Thanks
Good day all - I am following this conversation with some degree of concern. I am new to RR. I bought a 2015 RR L494 Hybrid end of December 2021 - after a week we went to Norway for 2 weeks. Driving from Voss to Geilo with icy roads and minus 10 the car showed a large number of failures (ABS, Break Reinforcements, Stability) - the driving options were limited to Auto, no other off-road of anything. Pretty scary when driving on challenging conditions. Car was towed away - warnings disappeared after the 12v battery was disconnected an whole night. Nevertheless they came back after 2 days. Did not stop till I was back in Germany and in Holland again. Seems the cold got to it (??) How is this possible with such a car? RR is now for inspection at the dealer. I am pretty concerned the hybrid battery is failing, understand the costs are pretty high (in the thousands of euros). I still have 5 months warranty so I want to make the case to replace both batteries since it seems this is THE common problem for this model. Any thoughts or experiences?
1 - 20 of 56 Posts
