I recently just replaced my 2003 Range Rovers PCV and I have all the hoses and wires connected but I forgot where the breather house is run to. I have it on the PCV itself through the spigot with the yellow clip but does anyone know where I should run it to? Thanks.
Make sure to disconnect the oil drain pipe assembly and banjo bolt ,number 6 in the diagram posted by Rattler1975 ,from below.It is a rediculously small bore pipe and if this is clogged (mine was!) it will just not drain and the system will fill with oil again!
