Dear members,
After some period without any troubles with my beautiful RR a failure popped up.
From one moment to the other the driveline/gearbox start rattling and the car is not moving without any message in the screen for failures.
I can easily start the engine in "P" but when i want to go to "D" it starts rattling agains as to gears/sprockets are "kissing" each other. It is an awfull noise and the car does not move at all. Does some of you have experience with this or is specialist who can give me advise where to start finding the failure.
Look forward to your reactions
Sybrand
Pull the rubber bung at the bottom of the bell housing and look in with a flashlite to see if all looks good and no pieces of metal fall out. Some have had the shaft break in the transmission. it breaks off from the hub that holds one of the clutch packs iirc.
Has your L322 had the front differential/propshaft modification? It might be worth checking if the front propshaft is turning when you are stationary in gear.
Phil
