seat not working .any info in a fix for the peliter unit . When you first start the car the fan will blow for about 30 seconds and then stop . But no heat from the unit . If the one doesn't work will that stop the other Stop working . As in back unit and base unit .
Any help would be appreciated
Andy
They're independent of one another. Do not try to diagnose by listening, it comes on for a duration then goes off normally. Its entire function is based on thermistors feedback. Seems 90% of the time it's the seat back unit is fouled. You'll either luck out and it's just cracked (which you can repair) or something internal has gone and it'll need replacement. IMO removing the seat is the best way to work on them. People say they've done it with the seat in the car, though I can't imagine how without throwing your back out.
