Engine swap part two underway. I decided I wanted more room and I wanted to redo my engine mounts before I put the new engine in.
I have had a GM 6.2 in my Range Rover for almost a year. And it was a bit of a hurried install. Lots of work. While I like the motor. An opportunity to buy a 6.5 turbo diesel out of a 2002 bus. It has a center mounted turbo. Upgraded stronger block and better flowing heads.
I started by cutting out the front cross member. Boxing in the frame and welding in a new piece of 2x4 tubing.
Monday will be the rebuilding of the engine mounts and plating the frame. I'm moving them up about 2 inches higher in the frame.
