I am having problem with my 1994 hard dash LSE air suspension. The pump keeps running but air suspension doesn't move up. Need urgent help please
If the pump is running you could take the line off the reservoir and check it's producing meaningful pressure by covering the line with your thumb. Be warned though that the reservoir may indeed be at pressure but the valve block is failing to direct it where needed so proceed with caution. Eas unlock and a diagnostic cable are must owns if you are to leave it as God intended with the EAS intact.
From the above we can start to figure further probable candidates for fault and go from there. Leak being easiest to repair, valve block and driver being harder.
Sent from my LG-H930DS using Tapatalk
