today i have tried to replace the faded radius arms pushes, i had the arms removed in workshop and sent them to engineering workshop to press the new britpart replacement part but the guy there told me i can't press because the new pushes are larger than the existing one, then i confirmed what he said to me by measurements i found the old one 6 mm outer diameter compared to the new part which measures 6.2 mm i went to britpart dealer he told me this is the correct part and it is larger when new i moved direct to the used spare parts shop and took 2 arms left and right and the 2 rear benhard and installed them except the benhard as the day finished to be continued later. what is going on now this dimension is correct? and if it is how this could be done?<br>anyone have his radius arm pushs changed before and how?<br><br>the car was shaking left and right at 20 km/h speed and violent shudring then less at highway the same as gilberted described i think the problem solved but i will confirm at high speed
