1 - 10 of 10 Posts
2010-2012 Range Rover Sport
The radio Volume on my 2011 RRS increases to maximum on its own. The frequency is from two or three times daily to once a week. Has anyone experienced this phenomenon and if so, what was the remedy ... software or hardware?
Thanks, usmcfred
When i owned a BMW 540 the radio volume would increase and decrease automatically on the motorway due to the extra road noise, maybe the sport RR has a similar system ?
but not to the maximum, something is not right.
Yes, precisely. This is not a gradual increase in volume to offset road or wind noise. It goes right to maximum volume in a second. Thanks ...
you may try battery disconnect.
turn the car off, open hood, wait 10~15 min disconnect battery and tach cables together.
That’s a standard Lucas design feature !
Maybe contaminated switches on the steering wheel - probably have to remove the wheel to access the switch and try cleaning with contact cleaner - or perhaps you can just try to squirt some in there (with battery disconnected) with the little straw .... but could be wiring short somewhere, firmware issue and a few other things .... I’d start with the switch
Thanks Buba and Alpaca for your suggestions. It happened again yesterday. I am getting good at turning the volume knob down quickly to prevent the speakers from getting blown out. usmcfred
There might be a way to control the speed or max volume setting with engine speed. You might try accessing some of the BCM inputs. These parameters may be user adjustable. Just a thought... Ray
1 - 10 of 10 Posts
