2008 Supercharged RR.
As the title. The screen stays on the Landrover logo and the radio etc does not work. I've tried...
Checking all the fuses and they are okay.
Cleaning the GPS disk
Disconnecting the bluetooth module and fitting an optical bypass adaptor.
All the above makes no difference. From searching the bluetooth module is often the culprit but obviously not in this case.
Any suggestions on what i can try next?
disconnect all of the elex systems in the left rear quarter panel,
verify that everything is dry.
No wet connections. Driving yesturday the radio and entertaiment system started working again. I then parked up came back 8 hours later and it wasnt working.
charge the battery over night and see if it helps.
this cars are very sensitive to battery voltage.
let us know, :thumb:
