Hi. I know this issue has been asked before, but each issue goes in different direction or drops off. I have an 03 RR HSE and I am a girl so please be patient with me. Suddenly today my radio was not working. First I noticed no sound, then I noticed that it will not turn on (orange light is off). Display screen works but I cannot turn radio on and I do not have access to CD/Radio/Cassette through the "mode" button because it will not power on.
I fiddled with the buttons on the steering wheel (not sure what r/t button is but nothing helped). I noticed the word "code" on the screen listed under off road nav (accessible in white) that is not accessible and is a dark grey that I do not remember seeing before. So unable to enter a code either.
I had my dad check the fuses in the glove box and they were fine. I want him to check the fuse that is on the radio module, but I need to know if the module needs to be removed in order to see the fuse. I know where to find the radio module (rear hatch, drivers side, behind panel) but once inside there it is intimidating. I read it "lives under the plastic floor cover" what does that mean exactly. How can i verify I am staring at the radio module vs. the other components in there and does it need removal to find the fuse?
Any help would be really appreciated. I would like to weed out the easy stuff before blowing $150 at the Dealer.
Thank you!!
P.S. Someone also said to turn engine off and "lock it" then restart again and it may reboot the system. What does that mean "lock it"? Thanks again : )
Thank you!!
