1 - 1 of 1 Posts
I recently bought a used L322, and the stereo worked like a charm until about three or four weeks ago. The previous owner has already by-passed the Nokia phone module with the standard workaround on the fiber optic cable.
When I bought this RR, I had to periodically remove the 15A radio fuse under the dash and then reinsert it for the radio to work. Then three weeks ago, that stopped working.
I did a hard reset by shorting together the battery cables, and that brought the stereo to life, but then it died again after shutting the engine off. Now, even a hard reset will not work.
Now, nothing happens--no orange light on the power button. Only the backlight for the buttons on the side of the head unit are illuminated when the headlamps are on.
This afternoon, I found that the fiber optic connector to the H/K Logic 7 unit was not plugged in, and it had not been bypassed, so I plugged it in, and still nothing. But I was able to see the flashing red pulse from the Logic 7 unit when the plug was out (thanks to a dentist's mirror). I haven't tried a hard reset since this.
When the stereo did work, it sounded brilliant!
Any suggestions?
Thank in advance.
(2005 Range Rover HSE, 4.4L BMW V8)
1 - 1 of 1 Posts
