I've been pouring over the hundreds of posts for Radio problems, but can't seem to find something that matches.
1998 4.6HSE.
Radio asks for code everytime I start the car. I have the code and it works. I punch the code in and I can see the FM stations, change stations, etc...
Only problem is NO sound. If I turn the volume knob, nothing on the screen indicates the volume is even trying to go up or down. Steering controls all work except volume. It's as if the unit isn't recognizing the knob turning or buttons being pushed.
I've tried popping fuses in/out. haven't popped the deck yet though.
Not even sure where to start. I haven't pulled the amp in the rear yet. Would that be the next option to test? I figured that at least the front speakers would work if the amp by the subwoofer was shot....
Thanks for any help.
Discussion Starter · #2 ·
Well, I figured out my own problem. It was the 3 amp fuse on the back of the deck.....go figure. There was one thread buried where I found it at. So if anyone is dealing with audio trouble...make sure to check that fuse...
