Hello
My englisch is not so good. maybe somebody helps me.
I have range rover model 2003 4.4 liters and it is prefekt till yesterday the r gear dont functions, i meen if i put the gear on d , it drives normally but the behind r when i put it it is like n , nothing happens .
Have somebody an idea?
As a temporary test, try disconnecting the 16-pin connector at the rear of the transmission.
This will operate the C & F clutches at maximum (unmodulated) pressure. If the transmission still won’t reverse then you have an internal failure that will require the transmission to be removed and rebuilt. Note that the transmission failsafe message will appear while the plug is disconnected – just ignore this for the test.
Phil
