I don't have the books on a 2013 rover I bought, is there a way to see the actual tire pressure on the dash display?..All I see is upon start up a display saying my tps is set to heavy load... is that even normal?thank you
· RIP Our Friend
boca, "heavy load" simply means your tyres are inflated to a higher pressure for hauling heavy items in the back or for towing. If neither of these situations apply, lower your PSI down to normal pressures and change your monitoring system setting.
· RIP Our Friend
VEHICLE LOADINGIt is possible to select different tire pressure monitoring levels that correspond to the tire pressures and load information on the tire pressure label for a light or heavily laden vehicle. See 221, TIRE PRESSURE LABEL(USA only).Note: Make sure that the tire pressures arecorrect for the vehicle load.The different tire pressure monitoring levels can be set via the Vehicle Set-Up menu in the message center. See 71, INSTRUMENT PANEL MENU.Note: The TPMS setting must correspond with the vehicle load.
