2013-2015 Range Rover Sport
Hi,
I have a 2013 RRS HSE Lux with the stock 20 inch rims and 275 40R 20 tires.
I am looking for a second set of wheels for swapping to winter tires. I found some OEM Land Rover wheels on eBay but they are fitted with 255 55R20 tires.
Does anyone know if the 2014-2015 RRS sport wheels will fit on a 2013? Looks like the sidewalls will be taller on the newer model year tires.
Thanks,
Ntrrs
SUPER MODERATOR
You'll need to check the offset...should be 53 I believe on both wheels. If so, I believe the bolt pattern of 5 x 120 is the same, but offset is the key issue.
Something to remember that tyres have absolutely nothing to do with if a wheel fit or not... Just as the size of your wheels has absolutely nothing to do with your speedometer accuracy.
Long and short is that yes, L494 rims will fit the L320. Bolt patterns are both 5x120, hubs/bores are both 72.6mm. HOWEVER, offset is 53 for 320s but is 49 for 494s. You will have to decide if that will create issues for your model and/or deciding which tyres to purchase.
