I decided I would perform a full brake refresh on my 2003 HSE, including the Brembo brake caliper mod, along with new rotors, pads, and fluid for all corners. I ordered these Brembo calipers from the 2006+ Supercharged from LKQ, but when I went to install them today, they don't quite fit on the stock caliper mounts.
The spacing is just a little off, and the bolts that go into the Brembo calipers are clearly a size larger than the ones that go through these caliper mounts.
What did I get wrong? Did I miss a step? Did I order the wrong Brembos? (If so, oops...)
Here's the Brembos I ordered: http://www.ebay.com/itm/311766366345?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Here's pics of the situation:
