1 - 13 of 13 Posts
2010-2012 Range Rover Sport
I swapped out all the regular filament bulbs for LED style awhile ago, but noticed that the two front door puddle lamps (the ones on the bottom of the doors) are not working. Swapped with two new LED bulbs but still not working. All other lights work fine. Tried to disable the interior lights by holding the centre light switch on the overhead console, then enable them, still not working. :???:
Anyone have suggestions?
2013-2015 Range Rover Sport
Did you make sure that the lights are CANBUS? Incandescent bulbs burn at a certain wattage, when that wattage is reduced, the vehicle presumes the bulb to be burned out and causes an alert. CANBUS LED's take that into account but non-CANBUS often will not work as the vehicle requires a higher amperage.
I rechecked the product description to see whether they're CANBUS or non-CANBUS and apparently, they're not. The fact that all the other LED's work fine, lead me to believe this wouldn't be an issue. Does that make sense?
Makes total sense to me. However these ECUs are very particular... like using the wrong rear brake lamp will cause totally non related error codes, low battery voltage will throw multiple errors that are all unrelated to each other. Seems like one problem triggers other non related ECUs to fail, making trouble shooting difficult.
So......buy new bulbs that are CANBUS. See how that goes. Good thing they're not too expensive. Still have the issue with the cargo light on the passenger side. Wire caught on something in the headliner. Anyone have thoughts on how to "pull" open the headliner back there?
all you need to do is solder small resistor in line, this will fool ECU to think it is regular bulb.
Discussion Starter · #7 ·
What size resistor?
to mimic 5W bulb. go to Radio Shack or similar and let them help you
Discussion Starter · #10 ·
Helmet Personal protective equipment Vehicle
May be a bit cheesy, but very cool look!
I presume that is a photo of your truck?
If so, looks like they work quite well.
Discussion Starter · #12 ·
Yes, that's my truck. Sorry the picture ended up being sideways.
I just figured you lived on the side of a mountain...
1 - 13 of 13 Posts
