So I have done a few of these over the last few years and every time I go looking for Pictures of the straps(I dont do enough to remember in my old age.) No instructions come with the kit and most of the posts out there are gone but Dons from NCLR on his LR3.
Here are my notes from install to help anyone doing this especially on a Sport.
1. To start I used my computer to depressurize the air springs.
2. Removed the 1 lower bolt on the front strut and place the jack under it. 24mm and 21mm Bolt and nut. View attachment IMG_20181121_083048297.jpg
3. Next I disconnected the electrical connector on the top of the strut (supercharged sport with dynamic suspension)
4. Then the three top mounting bolts 15mm. I use flex head ratcheting wrench on the front two nuts and a ratchet on the rear. I also start with the rear nut. Since the strut is sitting on the jack at this point I lower it a few inches to expose the air line and cut just above the rib on the hose (see pic)
5. The strut is free at this point. I remove the air line fitting from the top of the strut and installed the air line extension.
I put a little white grease on the brass fitting and line to help seal. When tightening this back in place just snug since it is brass and will strip.
6. Installed the plate and replaced the 15mm nuts.
7. installed the strut back in the car. Top bolts in the kit are 17mm
8. Reconnected the air line using supplied quick connect from the kit and the electrical connector. View attachment IMG_20181121_084253580.jpg
9. Note the front set up on the sport Does Not use the limit straps (as advise by L8) There is no place to mount the strap to the control arm.
Just my notes, it is pretty easy and straight forward but there are a few tips involved. I will follow up with the rear tips next.
