Well just when my reading of rr.net had led me to believe I should investigate my battery as the cause of my non-arming security system and inability to synch handset remote (aka key fobs), my RR wouldn't start this morning. She gave me a full panel of instrument lamps, several click click clicks, and a few fault codes including a few auf Deutsch, then sent me off in the wife's car. Tonight, barely enough juice to light up anything on the dash.
So I am in search of a battery. But no LR dealer nearby. Where do you stateside guys get your batteries, if non OEM? And what specs do you recommend?
Also, I want to check my main fuses. The rr.net page here http://www.rangerovers.net/repairdetail ... terference suggests a main fuse could be the cause of an unresponsive security system. How do I remove these maxi fuses? Just pull, like the little ones?
When I solve these problems I can finally relax. And start my heater o ring job.
Thanks,
Mike
Thanks,
Mike
