1 - 1 of 1 Posts
My name is Willy, I live in France and I am the proud owner of a discovery 3 of 2006.
I bought recently (6 months) a discovery of 230000 kilometers (gearbox had never been drained)
From the beginning, I had problems of idle speed variation in steady speed.
I made a first drain.
The problems faded slightly, but were still present.
I changed the torque converter.
The D3 has been metamorphosed in terms of driving and consumption. I thought my problems were solved.
5000 kilometers later, I had a jerk in the transmission at the approach of a stop. I had the "default transmission" information on the dashboard (and the P0741 fault code with my IIDtool).
I stopped the car. When I restarted it, there was no problem.
Since, I realized that sometimes the transmission does not work optimally (in this case, if I put my shifter on sport or in commandshift mode, there is nothing indicated on the board of edge - neither the term "sport", nor the gear on which I am).
At each start of the car, there is never a problem. However, I never know when the defect will reappear.
Since then, code P0741 has been displayed only 3 or 4 times. I had about twenty times the display of the transmission fault.
I think the ideal would be to change the solenoid TCC, but I would like to have your advice before I start the operation.
Do you know where I can buy a solenoid (and possibly other parts to change)?
Do you have a modus operandi to change this piece to provide me?
In advance, thank you for your answer
PS:I think you'll understand, I do not speak English very well ...
1 - 1 of 1 Posts
