which year and sound system? sound systems options vary quite a bit across the 5 years of 494s.
That is really cool.Curious to where this setting is too. I have the high-end Meridian and it drops the volume when park assist kicks in, but I don't see anything for speed-based volume.
In terms of conversation assist, not sure if that is tied to the audio system model, but here is how you adjust it. It works intermittently for me. I can't seem to determine the parameters when it kicks in, even when enabled to "Normal:.
Select All Settings via the SETTINGS pop-up menu. Select Features. Select Volume to access the VOLUME SETTINGS screen and manage the conversation assist feature controls. See SYSTEM SETTINGS.
Conversation assist offers three options:
When active, front passenger voices are reproduced through the rear speakers. The system is disabled when at a standstill and progressively increases with vehicle speed and background noise.
- Off: Touch to switch the system off.
- Normal: Touch to select the normal volume level.
- High: Touch to select the high volume level.
