95 Classic Short Wheel Base - what air pressure is each of the airbags at? I know the system pressurizes to 10 bar, but what is the pressure in each of the bags?
Depends on many things, height setting, weight of the vehicle, etc. The system uses the height sensors as opposed to pressure sensors to make adjustments.
However, as a guide i used to manually inflate mine to roughly 60-65psi in the front and 70-80psi in rear.
