Mine has been doing the same thing (I think) lately. I press up on the button, and about halfway up it slows, comes to a stop, the car beeps at me, and the window goes back down most of the way. My temporary fix has simply been to grab the window and when it starts having difficulties, I pull up and 'help it' slide the full way. Sometimes this doesn't work, and it gets stuck anyway.
shupack said:
Roll the window up till it binds, then use a screwdriver to push the seal down and lower the window.
I'm somewhat confused as to what this means. Would you mind explaining it a little more in detail as to where I'm looking to find this seal, and how far down I have to push the seal, etc. Thanks.
paul.adshead said:
(- put the window all the way down and keep spraying down the rubber channels)
So just spray down the 'crack' that the window slides?
