1 - 11 of 11 Posts
Hey all,
Just wondering, is there any kind of hard reset that can be performed on the automatic tailgates on the L405? I have a 2013, lower gate hasnt worked since I bought it a couple months ago (I can open it manually but does not work via power operation), upper tailgate was working fine until about a week ago but now it will only open and close manually as well. When you press the open close button on the dash (or on the hatch) it will pop/unlatch but then gives two audible beeps and wont open under its own power. Same when trying to close. Anyone have any experience with this issue?
Thanks.
RIP Our Friend
The two beep is telling you taht something is impeding operation. Has anything been caught in either section? Is there any resistance when opening manually?
Yes, this happened to mine while still under warranty. I had it in several times before they managed to fix it. The last time they replaced the wiring harness and a safety sensor. It has worked fine since then.
Thanks for the info guys. Nothing has been caught that I am aware of. It does have some resistance lifting and close the main/upper gate however i thought that was to do with the fact i was manually operating the motors instead of them working themselves. Sounds like this is going to be a dealer job?
RIP Our Friend
Well the safety sensor is what tells it something has jambed. Shot in the dark here... With your winters up there, do your road crews use salt or deicing chemicals? Could your hinges just need a good lube job?
le25, might you have the part number for that sensor on your paperwork?
Discussion Starter · #6 ·
Yes lots of salt and road grime over the winter. I only bought the truck about a month ago but it has been winter driver for sure before my purchase. I will go over the hinge for the lower section this weekend and give it a good cleaning and lubrication and see if that helps. I dont see how any debris could be caught up in the upper hinges though considering there location, anything to check for there?
I noticed a similar issue on a 2016 I'm looking at. I tried closing just the upper half with the power close button and it works fine. But when the bottom section is dropped and I press the close button, it starts closing then beeps twice and stops. Is there a separate sensor for the lower half and the top half? I would assume so. The bottom half seems to close fine by hand. Does it mean that the sensor for the bottom half is faulty?
While the bottom is open, lift up the small carpeted cover. Look down at the piston of the strong arm there. It may have corrosion on it, interfering with the operation. Shot in the dark. I haven't had the problem but mine did have a good amount of rust on it. I cleaned it up with steel wool and WD-40'd it as a preventive measure.
Sometimes you manually force close the upper and lower gates and start the car hit the dash board lift gate button and see if it opens and closes? That works on mine every time it errors beeps out.
I am having a similar issue with the 2013 RR. My lower gate opens normally (with power), but only closes by a few inches when I use power. I can close it manually.I removed the carpet and cleaned and lubed the struts and hinges. One of the struts seems to had minor corrosion. Unfortunately, it only got worse and now only moves 1-2". Anybody else have any ideas?
1 - 11 of 11 Posts
