I have been leaking power steering fluid for a while but just found the source of the leak this afternoon. There is a hose that I do not know the name of that goes from the steering box and curves up and around to the power steering pump. I wish I knew the name of the hose.(maybe pump pressure hose) It is the hose going under the other 2 hoses....
[attachment=0:ndcsxnnb]Hose to Change.jpg[/attachment:ndcsxnnb]
When you turn the steering wheel the hose will contract and expand. Well the fluid was squirting from the seams in the hose. I took a pic with my camera and took it to the parts store and ordered it up. I am now in PO-DUNK Texas. (Beaumont). I was in Orlando Florida. I plan on replacing the hose myself but I wanted to get some opinions before I started this venture. Is there anything I need to know ahead of time or is it pretty straight forward.
G
Well it's easier if you are a Gibbon. Only thing to say is that you should plan on losing some amount of steering juice, so buy some extra.
I just did this a couple weeks ago. Yes it's the high pressure hose. Yes you will loose brake fluid so be prepared with another quart.
If I remember correctly the nut on the line on the steering box side is 16mm? And the nut on the pump side is 14mm?
I think i also had to remove another line/nut on top of the steering box to have room to get to the high pressure line nut.
Good luck.
I can work wrenches with my feet, does that count? Tail don't work right though, comes off the wrong end and the damned thing has a mind of it's own!
I wish I knew what a "Gibbon" is/was but I got it changed with the help of my father-in-law. We had to move the alternator to reach the bolt on the pump. This thing was a pain in the :!: but I am glad to have it done. Now I have to figure out a home for a random hose running lose under the hood. Will put a post up in a few hours.
Occasionally you still have your moments...
can work wrenches with my feet, does that count? Tail don't work right though, comes off the wrong end and the damned thing has a mind of it's own!]
:D
Shaun,
I believe a Gibbon is a type of Monkey. Glad you got it changed.
You should remove them all, prior to removal I reccomend a couple cans of brake parts cleaner and a hi temp pressure wash. It made my life a lot nicer having all the oil and greese gone.
