I have a 4.6 autobiography Thor engine, 2001 plate.
I have had a problem with loosing power on two occasions. So I connected my code reader and it came back with a p0172 fault.
Can anyone help as to were to start looking to fix the fault
Thank you
JACK'S GRANDAD
Use the search function in this section.
Then go to the diagnostic section and read through the "Diagnostic trouble codes" list that is clearly at the very top of that part of the forum.
Once you've done that, you'll have a good idea on the issues you are having. This forum doesn't spoon feed folks, it points them in the right direction to help themselves.
Martin
