How did you order them? Through your US LR dealer?
KuduRover said:Those are awesome, but $4,000?? Geez, that is certainly not cheap but an awesome addition.
I used to think that this was rediculous too but then I started to think; I absolutely love this car and don't plan on trading it for at least five years and what is another $4k on a $90,000 car.RWDRIFT said:I like them alot. I just can't justify $4000 for some side steps.
Thanks for the additional info! Mine deploy only when I hit the unlock button (not upon park so there must be different settings).agoltz said:I do have the steering wheel position problem and was told by the dealer the unit was bad (there is a TSB on this) - it was ordered and I need to bring the car in to swap the unit. Something about the steering wheel memory going bad
The logic of the side steps does not always do what I would expect it to do but I have not had happen what you just mentioned.
The side steps deploy when you put in it Park - weird as you dont know if there are one or two people in the car. The side step of the passenger will stay down even after I lock the car and walk away (and the door was never opened) - it will retract after about 2 minutes.
I have not had the situation you mention although I would not be surprised that that happens if you place the car in R or N or D from Park if you close your door - this might be the idiot proofing where the steps delopy in case the door sensor is not working.
