Good Day
I would like to know where to start looking for this problem.
"No voltage at ECU Pin 1 when Ignition on"
I have all sort of funny problems with my Rangie and would also like to know if this can be related.
Which ECU? What are your symptoms? Is there an actual error code that has been pulled to go with that description?
rrtoadhall
It is an 1996 Range Rover 4.6 HSE.
symptoms : The car jumps between gears (Auto). i parked the car next to the road, put it in Neutral, give it a nice ref, Then back in to drive, no problem for 5 minutes, then again, gears no gears... Jumps around.
The error code , or print screen is as follow:
Code: 1.2.8 No voltage at ECU Pin 1 when ignition on
Regards
Which ECU? Engine, gearbox, other?
