1 - 1 of 1 Posts
2010-2012 Range Rover Sport
Hello all,
I subscribed to the topix service so I could get as much info as possible in case I really do need to replace one or both of my head gaskets. One thing that isn't completely clear is, as far as the cams are concerned, is it absolutely necessary to remove the cams to remove the head/s? It would be so much easier to remove the head still assembled so you don't have to deal with all of the cam timing which requires all of the special tools during reassembly.
If you absolutely have to remove the cams, are there work arounds to setting the cam timing, or are the factory tools required?
1 - 1 of 1 Posts
