Pls help me locate the coolant leak
1675 Views 3 Replies 3 Participants Last post by  jenzz
2
Hi,
I have a coolant leak at the front of the engine, next to the water pump. I believe it could be the water pump itself, but would appreciate your input.
This is what you see when standing in front of the radiator, looking down:
Range Rover 2000, Bosch Engine. I have recently done the heater O-rings and the throttle body heater gasket.
Water loss is not severe, barely noticeable.
there is a little hole in the water pump that lets you know the seal has been compromised, it usually dumps coolant in that spot
You probably need a new water pump. The pump usually runs for $120 to $150 and the repair isn't too bad if you want to do it yourself. Otherwise a competent mechanic should be able to do it in less than 2 hours.
Thanks, guys. Good to have it confirmed.
