I have a 2000 P38 4.0 (Bosch)
Will the exhuast system from a 1995 4.0 fit my 2000 4.0? I know the engines are different, are the shapes of the exhuast the same.
My ac compressor will not switch on to cycle. Freon is full, fuses and relays are good. It just blows hot. Is it bad or is it a swicth I can test?
for the exhaust, the Y-pipe with the cats in it, will not fit. Im pretty sure they are specific to Gems VS Bosch, since they use different o2 sensors. If its the rest of the system, it should.
Someone correct me if I am wrong.
That's right nickm347. The GEMS HO2 sensors are smaller than the THOR, so the holes in the Y section will differ.
This happened to me: Plug on the compressor was in place, but not pushed in to make the connection.
