2006 HSE
Is the engine order when facing my Rover from the front
7 8
5 6
3 4
1 2
I have three codes one of which is P0353. I also have two other codes on the 8 and 5. I switched some coils around but nothing happened. I also put a new coil in 3 but still have the code. Am I wrong in thinking I would be getting misfires if my coils were bad?
48
37
26
15
FRONT
Said another way the passenger side bank is 1-4
and the driver side bank is 5-8
NOTE this is for USA vehicles
do you see oil in the well of the plugs?
if oil is in the well then this can short out the plug/coil assembly
This condition means thet the cam cover gaskets need to be refreshed
Merlin, I appreciate your help. That means I changed out 2 instead of 3. You know there was a trace of oil on the coil when I removed it. My wife was hanging out with me and I told her I thought the gaskets might need to be changed out. At least that's easy!
