1 - 9 of 9 Posts
I just had a Pertronix and matching coil installed in a '93 LWB 4.2L, and so far it's running great. I did it because after fighting with the ignition for literally years, it died COLD at a stoplight, which it had never done before; I used to be able to coax it back to life with an igniter change or just letting it "sit" for a few minutes.
So I had it towed, and the shop confirmed the problem was isolated to the distributor. They suggested a Pertronix, and weighing the good/bad I've read here, plus the cost of an OEM dizzy with the possibility of ALL the recurring ignition headaches, I went for it. I believe they installed the single-wire version available for this truck.
The mechanic told me the ECU no longer had any control over the ignition, so I wondered about that.... but so far so good.
What are any failure modes I might look out for? I'm still driving with a bit of nervousness.
Awesome move on the new distributor
You should be fine from what I’ve read...
But..... you said....” I'm still driving with a bit of nervousness”....
It my belief with the rover
You probably always will
Have that ..,.
But no worry’s
It’s running good
Go with it
Mike
Bit worried that your mech though the ECU ever had any control over the ignition though. I went with 123 and it's night and day. Think anything beats lucas, the lord of darkness!
Sent from my LG-H930DS using Tapatalk
I have one in my 92 SWB, because the original went out. Works fine. Fit was perfect and pretty much like OE.
I did have to take off the module on mine because it conflicted with an aftermarket module the previous owner installed.
Following.
Mine has been eating coils and I can't find a reason for it.
Following.
Eating Pertronix coils? This has ME concerned; what are the symptoms when it happens so I can be aware?
I read with interest the parallel thread by someone who installed a different dizzy by SimonBBC(?), that seems to retain the AB relocation kit. SOunds like a clean installation, but I am MORE than happy to be rid of the relocation kit entirely. My Pertronix looks like it has a single wire leading to the new coil mounted on the fender, without the re-location kit claptrap of the previous setup.
Been driving it a week now, fires up instantly, idles nice, accelerates well, and by the gas guage (I'm sure it's my imagination), getting better mileage. I'll post again when I calculate actual mileage.
I'm kinda annoyed because the shop I used will always install parts that I buy, and in this case I sent the guy web images of the 2 Pertronix dizzys available for my truck to see which one he would prefer to install, and he went ahead and ordered one himself. He charged me double what I could've bought it for myself. Should have just bought both myself, gave them to him, and returned the one he didn't use. ARRRGH!
Don’t take this personally...
But you do realize
Mechanics think that you, me, we, are just a bunch of idiots
Before I would take my Rover to one
I’d burn it to the ground
( hypothetically of course
And it just sounds good)
and get another one...
My opinion of course.....
There is enough information out there to do anything
And they are simple ...,
I always read about having deep pockets
Your post is a perfect example
Good luck on your Rover adventure
Mike
I've done a _hit-ton of work on my '94 that a lesser man would've taken it to a shop to do. I've removed/dismantled/re-built my dizzy myself a few times, and installed the amplifier re-lo kit myself, too, so I ain't 'fraid of getting my hands dirty. Considered a Pertronix swap previously, too, but the consensus there is NOT unanimous, so I never did it. But any RR owner will attest to the fact that they are a singularly INFURIATING vehicle at times, while at others (when they're operating well) they're the most satisfying thing in the world to drive. This particular dizzy failure came at a time when:
1. I was suffering mightily from Lyme disease and had no physical energy
2. Kid was driving the car to school/gym/work and thus was in constant use and could not languish while I "got around" to fixing it
3. Failure occurred in the middle of an intersection so I had to have it towed IMMEDIATELY without knowing exactly what was wrong, and thus did not have the luxury of determining that I could fix it myself with my existing knowledge
4. Wife was on the rampage with existing "projects" still un-finished at home, and me towing home a vehicle she considers an eyesore anyway would've been the kiss of death for the Rover AND me
So yeah, I agree about taking it to a mechanic, and I KNEW the fix would be something I could've done myself, but other aspects of life get in the way sometimes.
All good points....
But I did say to don’t take offense ...,
I was just posting my thoughts
Which are worth ...I’d say about a hill of beans....
Being proactive.....I’d say you got that going ....it’s all an adventure
Mike
1 - 9 of 9 Posts
About this Discussion
5 Participants
Mikieman
RangeRovers.net Forum
Full Forum Listing
