I have a 1996 P38. Passenger side window will roll down and up, but won't fully close and fault appears. What do I need to do to get it to function fully?
This door also has a failed lock mechanism. It will unlock when I unlock the car, but not lock when I lock the car. Not sure if they are related or not.
Newbie here, so be gentle.
Thanks.
Brett
You really haven;t given us anything to go on. You will need to pull it apart and see. Could be something binding or you could have teeth missing on the regulator.
BTW, you can hardly be called a newbie having been here almost a year. Both your window issue and lock issue are covered quite well.
Does it go up straight and then reverse as if hitting a restriction? Or does it go up and then tilt forward?
Will it go up if someone presses the button while you assist it?
