Well fellas, I need some help/direction. My passenger side window was recently broken, and I was able to locate a replacement locally. I was only able to get one track onto the left arm but the right arm, I can not seem to get it on. Any ideas or techinques to fitting the right arm onto the right hand side of the glass track (gold piece)?
Much appreciated..
Searching owns me...
I have done it a couple of times when replacing window regulator.
Cannot remember fully but found it very straight forward.
I do remember moving the window mechanism so that you can get to all connections.
Copy from RAVE:-[attachment=0:1qjorh98]Capture.JPG[/attachment:1qjorh98]
Thanks for that... could you provide the 1st through 12th step? I would appreciated it. It would help me to get a clear picture on the process.
You need to get a copy of RAVE if your working on the p38. FOC, do a search on here.
No.1[attachment=1:3jxzxo6b]Capture1.JPG[/attachment:3jxzxo6b]
No.2[attachment=0:3jxzxo6b]Capture2.JPG[/attachment:3jxzxo6b]
