the cup holder on the passenger side seems to be jammed or stuck. is this a known issue. i tried prying it open but no luck getting it to pop out. is there a fix other than replacing that anyone knows of?
2006 RRSC 4.2
You will likely have to remove the unit to inspect it. Occassionally the unit becomes stuck and can be repaired but not usually in situ. Once removed if it is in fact broken is is almost always the clock spring mechanism which is non-repairable. You will have to get a whole new unit. Taking the passenger dash side panel off is the start, see attached instructions.
