92 RRC (no memory board)
Completely disassembled and cleaned the seat switch. Second time doing this. The first time, I used a bit of superglue to hold the bearings to the top of the tiny springs. I thought that was the issue and it took a while to clean up (got all of it) and reassemble. No superglue this time and do not recommend using it.
After install all of the other seat switch functions work but forward and back. Not happy. I will check the wires to the motor tonight. I will also try connecting a battery to the seat motor wires and see if there is any movement.
I may have a bad seat motor, but not sure my symptoms align with this. Thoughts?
