As of late, I receive an error message every time I start the engine “Cameras not available. Please consult Dealer”. I checked the fault code and I get:
PAM – Parking Aid
BIB42 – 96(2F)
Front left inner sensor
Is there a quick fix for this that I can perform myself relatively easily?
Thanks,
Gerd
The parking sensors and wiring are easily damaged. Some members report that the sensors make a humming sound if they have failed. You may give that one a listen. You can also slide the bumper cover off and inspect wiring and connections for damage.
I replaced the wiring harness on my rear sensors took less than 45 mins. I had an error that several sensors were bad. Turned out to be the harness. Very easy fix and the new harness I got from LR was a lot better than the one that came from the factory.
Sometimes they throw an error if they get dislodged a but too... See if it's still seated properly.
C$388 later, all is good again. It was the sensor correctly identified by the GAP IID Tool.
Shouldn't you still be under warranty for that?
