Looking for ideass, my 2006 v8 sport parking system has completely stopped working. Symptoms are as follows . They would work perfectly most of the time. Sometimes when selecting reverse they fail to activate, no beep , no switch light, reversing lamps on . Take key out , lock and unlock from the fob replace the key they will then work . Now over the last few days they have stopped altogether . Fuse 36 is ok , there is power going to the control module and I have tried swapping that with a know good one. Power to the module via two of the wires on the larger plug , no difference if reverse is selected . Has anyone come across this before ?.
