2013-2015 Range Rover Sport
I am getting U2002 fault code and park brake warnings are all on. If anyone has any other places or things to check please add your input. Here is where i am at. I have traced all the wiring from the switch to the park brake module and I have continuity with no shorts, I have the 2 grounds on the module. I have checked all the wiring at the left rear connectors and all looks good, no corrosion or breaks in the wires that i can find. What i am looking for is the wiring diagram for the power circuit. I have looked through the manuals and can not find the park brake circuit wiring in there. (I think i have all the manuals downloaded) I have not replaced the switch(I am going to try the one out of the other sport) but i did pull it apart and it looks good (no broken solder joints, burnt spots, corrosion or moisture ingress...)
I am in a similar situation as you and wondered if you have had any success?
How did you trace all the wiring as figuring oout what goes where is really tough with no wiring diagram?
